Lost sound settings
D_IMAN
Rising Star II
As you know, Microsoft very often releases cumulative updates.
So after installing these updates, my sound settings fly off!
"Hardware Audio Acceleration" is automatically enabled, and "DTS Audio Processing" is automatically enabled.
And I have to adjust the sound every time...
Why is this happening???
I have Windows 11 installed
All drivers and Bois are downloaded from the ASUS website.
Notebook model: Vivobook Pro 14X OLED (N7400\X7400PC)
@Falcon_ASUS I need help...
The latest update I installed was KB5016691
And after installing it, I have a sound settings fly...
32 REPLIES 32
Falcon_ASUS
D_IMAN
Lost sound settings
@D_IMAN
Could you please tell me the BIOS and system version you are currently using?
[Notebook] How to check the model name and BIOS version | Official Support | ASUS GlobalWhich version of Windows operating system am I running?Also, what is the audio driver version you are currently using?
D_IMAN
Rising Star II
@Falcon_ASUS
Windows 11 Pro x64 21H2 (22000.918)
Bios: 10.1.2.301
DTS Audio Processing: 1.10.9.0
Realtek: 6.0.9231.1
Falcon_ASUS
D_IMAN
@Falcon_ASUS
Bios: 10.1.2.301
Realtek: 6.0.9231.1
@D_IMAN
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Falcon_ASUS
D_IMAN
@Falcon_ASUS
Bios: 10.1.2.301
Realtek: 6.0.9231.1
@D_IMAN
The technical unit used the same laptop as you to update and install the KB, and it can be used normally. We would recommend you remove the audio driver and KB5016691 and reinstall them again. Sorry for any inconvenience it may be caused.
