Lost sound settings
D_IMAN
Rising Star II
As you know, Microsoft very often releases cumulative updates.
So after installing these updates, my sound settings fly off!
"Hardware Audio Acceleration" is automatically enabled, and "DTS Audio Processing" is automatically enabled.
And I have to adjust the sound every time...
Why is this happening???
I have Windows 11 installed
All drivers and Bois are downloaded from the ASUS website.
Notebook model: Vivobook Pro 14X OLED (N7400\X7400PC)
@Falcon_ASUS I need help...
The latest update I installed was KB5016691
And after installing it, I have a sound settings fly...
32 REPLIES 32
D_IMAN
Rising Star II
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/225233#Comment_225233
@D_IMAN
The technical unit used the same laptop as you to update and install the KB, and it can be used normally. We would recommend you remove the audio driver and KB5016691 and reinstall them again. Sorry for any inconvenience it may be caused.
The point is not specifically in KB5016691, but in the fact that after each cumulative update, the sound settings fly off...
Falcon_ASUS
D_IMAN
https://zentalk.asus.com/en/discussion/comment/226027#Comment_226027
@D_IMAN
Due to your description below, so I reported your condition.
"The latest update I installed was KB5016691
And after installing it, I have a sound settings fly..."
If your situation occurs after a lot of updates, I may need you to provide a clearer operation to verify your problem.
D_IMAN
Rising Star II
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/226043#Comment_226043
@D_IMAN
I'll wait for the next cumulative update from microsoft, and write about the results...
D_IMAN
Rising Star II
@Falcon_ASUS
Cumulative update KB5017328 (Build 22000.978) has arrived
And again the sound settings have flown !!!
I had to set it up again...
D_IMAN
Rising Star II
@Karen_ASUS And I noticed one more thing.
After updating DTS APO driver to version V1.10.28.0
When you turn on / restart the laptop, the sound becomes noticeably louder!
I have to open "DTS Audio Processing" and turn it on and off first each time...
Is it related to this feature?
Smart AMP Introduction | Official Support | ASUS Global
