11-29-2021 01:40 PM
01-14-2022 06:56 AM
XperiAndrihttps://zentalk.asus.com/en/discussion/comment/199406#Comment_199406
So I uninstalled the AMD driver completely.
Then installed. Of course, it didn't help and now I do not have AMD Software installed and I don't know how to install it.
I am almost sure that it is caused by the first or the second updated item:
01-14-2022 07:54 AM
XperiAndriwho said you needed link permissions to post links? 😳I cannot post a link.
See Reddit theme "Rog flow x13 usb-c displayport problem" answer from "Butwhynotme".
My guess was correct.
01-14-2022 01:51 PM
jp1This is what I did https://www.reddit.com/r/FlowX13/comments/p7hqhu/comment/hsojq6n/?utm_source=share&utm_medium=web2x&...https://zentalk.asus.com/en/discussion/comment/201253#Comment_201253
Is there any way to roll back these firmware updates? The dates match pretty well with the time I started experiencing issues.
01-17-2022 01:46 AM
01-17-2022 02:43 AM
XperiAndriFor me, did this not solve the problem. I have also double-checked that the USB-C connectors I am using are not malfunctioning with my roommate's laptop.https://zentalk.asus.com/en/discussion/comment/201255#Comment_201255
This is what I did
For now, it helped. I will post an update if it break again
