Dual Monitors for ASUS S410U Laptop - Help.
farcas
Looking for a way to use 2 monitors with this laptop. I have 2 Dell monitors for my Dell work laptop that use the USB-C output on the Dell laptop to a Dell docking station where the 2 older monitors are connected with DisplayPort.
My ASUS laptop outputs are USB-C and HDMI. When I connect the ASUS to the Dell docking station no response, so I assume they are not compatible.
All I want is to be able to use both external monitors and act as "dual" monitors with extended display so I can move apps back and forth. I don't need the other functionality of a docking station, just the ability to have 2 ext monitors.
I looked for splitters but I cannot find a "HDMI to DisplayPort splitter", only a "DisplayPort to HDMI" splitter.
Any help is appreciated.
basavantpms
If you use dual monitors with your ASUS laptop, which has USB-C and HDMI outputs, and your Dell monitors are connected via DisplayPort through a Dell docking station, you may face compatibility issues. A simple HDMI to DisplayPort splitter may not suffice. Consider exploring a PR Agency in Jakarta for alternative solutions or adapters that support your specific setup for extended display functionality without needing a docking station.
Falcon_ASUS
@farcas
May I ask if you could provide me with the complete model number of the laptop you are using?
This way, I can verify its specifications.
How to find Model Name
