No USB-C display output on ROG Flow X13 GV301QE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-29-2021 01:40 PM
I've been having issues getting USB-C displays to work on my Flow X13 running Windows 11. I've tried a variety of docks/adapters, restarting my laptop, resetting my BIOS, messing around with drivers, nearly everything I can think of short of a factory reset.
Occasionally, I can get an image to show up on my monitor if I fully turn off the laptop (not just restart, but literally 'shut down' and then turn it back on again) but if I unplug and replug the type-c adapter into the same port, I will once again get no image.
Does anyone know of a solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-30-2021 11:33 PM
Which monitor are you using? please share the brand and model.
Does the monitor has it's own power supply?
Does the issue happen on HDMI port?
And which type C did you plug in? Right or left one?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2021 11:58 AM
Blake_ASUSNeither USB-C port works and the issue happens with different monitors (primarily tested with my asus VG248) and adapters, including a StarTech hub, Insignia adapter and one other.Hi there,
The issue does not happen on my laptop's HDMI port, just USB-C.
Also, how do I enable email notifications on this forum?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2021 06:23 PM
Was there any specific update before the issue occurred?
let's check in the Windows update history.
And beside display, does the type C work with other function?
like data transfer, charging...
You can find the notification preference by pressing the "bell" icon and the upper bar of the forum.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2021 06:33 PM
Blake_ASUSI believe this issue started since updating to Windows 11 but am unsure. USB-C works with everything else except display adapters.Hi there,
