03-27-2025 06:22 PM
My Zenbook S15 UM5606WA does not detect my portable monitor (i.e., Arzopa Z1FC) when I use the usb type C to type C cable provided by Arzopa. It says there is "no signal" and when I try to detect it in laptop it says that it cannot find another display.
The type c cable and portable monitor are working as I've been using it with my Zephyrus G14 2020. It is just now when using it with my zenbook s16 that I am experiencing this problem.
I already tried reinstalling the display adapter and the usb controllers but still doesn't work. I am starting to doubt Asus' claim of the usb4 port having display output capability.
03-30-2025 05:49 PM
@WN3333
The USB Type-C port on the UM5606WA supports display functionality.
Have you tried using different USB-C cables for cross-testing?
Alternatively, I would recommend referring to the FAQ provided by other users for troubleshooting.
03-31-2025 01:37 AM
Followed the guidance from the FAQ but still doesn't work. As per the manual, this model is usb 4 which supports display functionality however it just provides power to my portable monitor but does not provide display signal.
03-31-2025 05:25 PM
@WN3333
Its specifications are as follows:
https://www.asus.com/laptops/for-home/zenbook/asus-zenbook-s-16-um5606/techspec/
If you have already gone through troubleshooting but the issue persists, we recommend taking your laptop to a service center for further diagnosis.
04-01-2025 02:45 AM
I haven't even used this laptop for a week and it already has problems. that sucks.
