Zenbook UX550GE Touchpad problems
ahalol
System: Asus ZenBook UX550GE
Battery or AC: Both
Model: UX550GE
Frequency of occurrence: Always
Reset OS: Not Effective. Same even in Linux
Screenshot or video:
Detailed description:
Since I bought this laptop, it has been suffering from interrupted touchpad. I thought this was how it supposed to be until lately I met a new friend who happen to own the same device. He pointed me to this thread https://zentalk.asus.com/en/discussion/39758/zenbook-ux550ge-touchpad-problems which clearly, I should've done an RMA so that the touchpad firmware can be updated at Asus factory. Hence, I wonder if my device is eligible to this repair. Could someone please help? I purchased an Asus ROG M16 but I am still using the device daily and would like to have this fixed.
4 REPLIES 4
Falcon_ASUS
ahalol
  1. System: Asus ZenBook UX550GE
  2. Battery or AC: Both
  3. Model: UX550GE
  4. Frequency of occurrence: Always
  5. Reset OS: Not Effective. Same even in Linux
  6. Screenshot or video:
@ahalol
If the same problem occurs in different systems,  I would suggest you bring back your laptop to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
If the laptop is out of warranty, there will be a fee for repair.
ahalol
Falcon_ASUS
https://zentalk.asus.com/en/discussion/62707/zenbook-ux550ge-touchpad-problems
@ahalol
Thank you for the response. The issue is that if this is a repair needed by Asus's factory to conduct firmware upgrade, why should I pay?
willjoe2442
How to Fix a Touchpad Mouse That Jumps
Turn your computer off and then clean your touchpad. Dampen a clean cloth with some isopropyl (rubbing) alcohol and then pat the pad dry with a paper towel.
Re-calibrate your touchpad.
Use the manual troubleshooting wizard.
Reduce cursor speed.
Regards,
Will
ASUS_Bot
Rising Star II
