Problems with Touchpad and ScreenPad on the Zenbook Pro 15 UX535LI
AlexTugui
Hello,
I have some problems with the touchpad and screenpad.
The touchpad doesn't show in the Device Manager , the F6 key (the key for selecting the mode for the screenpad) does not work.
The problem started suddenly. The ASUS ScreenXpert Optimizer gives me the error code: 0x00000010
Falcon_ASUS
@AlexTugui
Please go to Safe Mode to verify whether the touchpad device appears in Device Manager.
[Windows 11/10] How to enter Safe Mode
If the device still doesn't appear in Safe Mode, it's possible that there's a hardware issue with the touchpad, I would suggest you bring back your laptop to our service center for further confirmation.
