Weird Stuttering Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-05-2022 07:14 PM
Battery or AC:
Model: Q538EI
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hi everyone, I got a really weird problem of my Zenbook Flip. Every time I move/hold my laptop, plugged or unplugged, it becomes super slow, the cpu usage decreasing drastically, it's like the hardware is heavily bottlenecked. However, after I keep it stationary, the laptop performance resumes to normal after ~30 seconds.
I am suspecting the internal gravity sensor is somehow messed up (I could be totally wrong about this), and don't know how to fix it. I also tried contacting the customer service, through where I found no valuable solutions, unfortunately. (I was told to reinstall display drivers and restore windows. I did not think the problem has anything to do with the display, yet I still reinstall the drivers downloaded from their provided links. After that nothing changed, the problem persists.)
Any suggestions/solutions would be appreciated. Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-05-2022 10:38 PM
lcmwan53@lcmwan53
- System: Windows 10
- Battery or AC:
- Model: Q538EI
- Frequency of occurrence:
- Reset OS:
- Screenshot or video:
Does the problem still exist if you enter safe mode?
[Windows 11/10] How to enter Safe Mode | Official Support | ASUS GlobalIf the problem persists in safe mode, I would suggest you to restore your system.
[Windows 11/10] How to reset the PC and remove all of my personal files, apps and settings | Officia...Sorry for any inconvenience it may be caused.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-06-2022 11:45 AM
Falcon_ASUSThanks for the quick reply. I tested on the safe mode, and it seems that the issue is gone. Then I clean reinstalled windows 10, let it self-update, and the issue reappears. What do you think may be the issue? Thank you.https://zentalk.asus.com/en/discussion/61820/weird-stuttering-problem
https://www.asus.com/support/FAQ/1013018/
https://www.asus.com/support/FAQ/1013064/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-06-2022 08:18 PM
lcmwan53@lcmwan53https://zentalk.asus.com/en/discussion/comment/217641#Comment_217641
If there is no problem in safe mode, it may be that the third-party software you installed conflicts with the program of the system itself, which causes the problem to occur. You can consider removing the installed programs gradually, and then check whether the problem is improved. Alternatively, you can restore the system directly and confirm whether the problem is improved under the system default conditions. Sorry for any inconvenience it may be caused.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-07-2022 07:53 AM
Falcon_ASUSSorry for not clarifying clearly in my last reply. I reinstalled windows 10 with official iso, applied windows update, and tested. I did have any 3rd party software installed yet before the test. I guess the only software I installed (actually windows installed for me) is MyASUS.https://zentalk.asus.com/en/discussion/comment/217745#Comment_217745
