02-22-2022 01:26 PM
02-22-2022 01:35 PM
02-22-2022 09:51 PM
loftub1@loftub1that was not meant to happen....2) reinstalled battery. 3) updated keyboard drivers sent by asus support uk. Wondering is there anything else i can try to get it working or based on its age should i consign to the scrapheap? Any suggestions and advice appreciated. Trying to work using an on screen keyboard is painful......
Falcon_ASUSSorry for any inconvenience it may be caused.Please test with an external keyboard, test what you call these not working characters, could these characters work normally on an external keyboard?
If these characters can be used normally on the external keyboard, it means that the keyboard of the laptop itself may be wrong, and it is recommended to send it for repair.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
