Lost sound settings
D_IMAN
Rising Star II
As you know, Microsoft very often releases cumulative updates.
So after installing these updates, my sound settings fly off!
"Hardware Audio Acceleration" is automatically enabled, and "DTS Audio Processing" is automatically enabled.
And I have to adjust the sound every time...
Why is this happening???
I have Windows 11 installed
All drivers and Bois are downloaded from the ASUS website.
Notebook model: Vivobook Pro 14X OLED (N7400\X7400PC)
@Falcon_ASUS I need help...
The latest update I installed was KB5016691
And after installing it, I have a sound settings fly...
32 REPLIES 32
D_IMAN
Rising Star II
Update KB5018427 (Build 22621.674) arrived yesterday
Sound settings are not off!
D_IMAN
Rising Star II
@Falcon_ASUS Update KB5019509 (Build 22621.675) arrived yesterday
"Hardware audio acceleration" and "DTS Audi Processing" were automatically turned on again...
The volume remains unchanged!
OS reinstalled a week ago...
Falcon_ASUS
D_IMAN
@D_IMAN
In your previous reply, you mentioned that after updating the KB everything works fine. If the original setting is changed after updating the new KB, it is recommended that you can reset the sound settings. Sorry for any inconvenience it may be caused.
D_IMAN
Rising Star II
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/233377#Comment_233377
@D_IMAN
And how to do it?
And why is this happening?
After all, after a clean installation of 22H2, several KB were already installed, and everything was in order with the sound settings!
And now it's started again...
D_IMAN
Rising Star II
@Falcon_ASUS Update KB5018496 has arrived
And again turned on the hardware acceleration of sound and DTS Audio Processing.
Are ASUS developers going to fix these problems somehow?
