11-29-2021 01:40 PM
01-19-2022 09:25 AM
nicholasleesThe external U2717d monitor connects just fine... Not sure why it would work with this one but not the U2414h monitors.I just bought a x13 flow and discovered this same error today when I tried to use it at work with my dual Dell U2414h monitors through a USB-C to Mini-Displayport adapter. It does not detect any external displays, and nothing I have tried from Reddit or elsewhere seems to fix the issue. Prior to this, I had successfully used a Surface Pro 6 at work with no issues. This USB-C to Mini-DP adapter was also used successfully yesterday at my home setup on a Dell U2717d, I'll have to take it back home tonight to try again and see if it detects it.
01-19-2022 11:32 AM
01-20-2022 12:39 AM
nunoliveira89Hi there,Hello,
One more over here. i'm having problems with the hdmi port.
The port sometimes works, but other times it detects the external monitor but don't have any image.
I have a dock station connected to usb-c and the monitor connected to the usb-c port works well. My only problem is with hdmi port
01-20-2022 12:42 AM
nicholasleesHi Nicholas,Another follow-up. I was able to get a USB-C to HDMI output working to the Dell U2414h, but for some reason, it doesn't recognize the USB-C to Displayport. I was able to use that output for one monitor and the standalone HDMI port for the other monitor. It wasn't ideal, but it did allow me to drive two external monitors.
01-20-2022 07:32 AM
Blake_ASUSHi Blake,https://zentalk.asus.com/en/discussion/comment/201912#Comment_201912
Hi Nicholas,
You said you can connect the Type C port with U2717d, then can you keep this connection and connect U2414h to the HDMI? Then you would have 2 external monitors.
Or do you mean it only support one of the above connection at one time?
