BT10 keeps dropping 2.6ghz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-13-2025 02:29 PM
Twice since I set up the three BT10's, the 2ghz has dropped from the mlo interface and all my 2ghz iOt devices get connected back to the main hub vs the node that may be 40feet closer to the device. If I reboot the system everything goes back to normal. Any thoughts?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-13-2025 06:23 PM
New issue tonight, I did a factory reset an started over, now mlo is only using the 5g & 6g the status for the mlo shows the 2g as ---. this is getting frustrating, I returned the BT8 last week as is was very unstable and constantly logging errors. This is my first experience with ASUS mesh and I'm not finding it very pleasant.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-14-2025 06:43 AM
MLO is for WiFi 7 only. Did you create a Legacy/IoT SSID? It should have asked for 2/both.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-14-2025 07:04 AM
I have a separate iot SSID, the main SSID is wifi 7. When I first set it up from a factory reset it shows using all the bands in the MLO backhaul. (Although the last factory reset from last night the 2ghz did not show in MLO status) It will drop the 2ghz band sometime later.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-14-2025 08:19 PM
Turned off wifi 7 and things seem to be stable for now. My Sony Bravia 8 tv could not connect with wifi7 on.
