03-19-2025 11:51 AM
I have a problem with the RT-BE58U. When my Zenfone 10 is connected via WiFi 7, the internet connection keeps dropping. This only happens with an MLO connection. The Zenfone is connected to WiFi. At some point, it disconnects and reconnects. After that, it works again for a while. This doesn't happen when MLO is disabled. Devices without WiFi 7 don't have this issue.
Solved! Go to Solution.
03-20-2025 07:13 PM
Hi @kleiderhaken ,
Thank you for your inquiry.
To better understand the Zenfone 10 connection issue you are experiencing, please perform the following tests and provide information:
Please follow the steps below to report the issue, and we will assist you:
Additionally, please send us the following information via private message: product serial number, the time the problem report was submitted, the email used for the problem report, the time the issue occurred, the MAC address of your device, and a network architecture diagram of your current environment.
If your network is down, the UI page will generate a link for downloading offline data. Please click the link to download the data, compress it into a ZIP file, and provide a cloud link for us to analyze.
Thank you for your cooperation.
03-19-2025 10:11 PM
I just got my BE58U but my phone has only 6E. I didn't face any issue with a MLO SSID due to the fact that my phone doesn't have WiFi 7. Can you screenshot your MLO SSID settings details from the app or the web ui?
03-20-2025 06:22 AM - edited 03-20-2025 07:06 AM
When MLO is disabled, everything works, and the internet doesn't drop out intermittently. While the internet is down, I can still access the router. So, the connection is working. Only the internet isn't getting through. The Zenfone is the only device on the network with Wi-Fi 7. All the others don't have any issues with disconnections. I'm almost convinced the Zenfone is the problem.
03-20-2025 07:13 PM
Hi @kleiderhaken ,
