Problems with Router App's External Connections
hahahazh
I am using a TUF AX3000 router and this problem occurs with router app on Iphone. When I connect to the router via WLAN (internal connection), everything works normally, including the speed. However, the problem occurs when I connect externally (either through another Wi-Fi network not provided by my router or via 4G). The response speed becomes significantly slower. How can I solve this issue?
Aureliannn_ASUS
Hi @hahahazh ,
To better assist you with your remote connection issue, we recommend that you check the following:
  1. Network environment: The stability, latency, and bandwidth of your network when using other Wi-Fi or 4G networks can affect the responsiveness of the app. We suggest you try testing in different network environments to see if it is a network environment issue.
  2. Remote management settings: Please ensure that the remote management function of your ASUS TUF AX3000 router is correctly configured. You can find the relevant settings in the router's management interface and ensure it is enabled and configured correctly.
  3. Firmware update: Please ensure that you are using the latest version of the ASUS router app and firmware. You can update through the app or the router management interface.
  4. Network firewall: Some network environments may enable firewalls or security settings that restrict remote connections. We recommend that you check your network firewall settings or contact your network service provider for assistance.
jzchen
Zen Master II
Do you have symmetric service such as fiber where upload and download speeds are the same?
