One of the fans does not work after waking up from sleep. (vivobook pro 15 OLED)
- System: Windows 11
- Battery or AC: AC
- Model: X3500PC
- Frequency of occurrence: Almost every time after waking up from sleep
- Reset OS: no
- Screenshot or video: yes
Detailed description:
Almost every time after waking up from sleep mode and plugging my laptop into charging, the left (GPU) fan stops working, but if I reboot it, everything is fine and it starts working. I did diagnostics in MyAsus and it did not reveal any problem.
P.S. I turn on the charge so that there is maximum performance. I did not bring it to high temperatures so that nothing would break.
Normal temperature under load is CPU - 80°C and GPU - 70°C
0
Comments
Similar issue: https://zentalk.asus.com/en/discussion/43106/vivobook-pro-17-n705fd-gpu-fan-not-working
@0TimeLord0
Your model is different from the model discussed in this post.
Have you updated your system and BIOS to the latest?
I don't have update notifications. Most likely all the latest versions.
@0TimeLord0
I would recommend that you enter safe mode to confirm again.
If the fan still doesn't work after waking up in safe mode, I would suggest you try to restore the system.
