02-25-2025 04:18 AM
I’m experiencing a problem with my ASUS TUF Gaming F15 (model FX507ZC4).
When I shut down the laptop, I often struggle to turn it back on. I’ve tried several troubleshooting steps, including:
Despite multiple attempts in different combinations, the laptop eventually powers on, but it seems random and unreliable.
Interestingly, the power button works perfectly for putting the laptop to sleep and waking it up — the issue only happens after a full shutdown. Once the laptop is off, pressing the power button doesn’t respond immediately, and I have to go through a series of retries before it finally starts.
I’d like to understand what could be causing this and how to fix it. Could it be a hardware issue, or is there something in the BIOS or power settings that needs adjustment?
Solved! Go to Solution.
02-25-2025 04:35 PM
@Blackmesaja
It might be caused by a stuck power button. If the issue persists, we recommend that you take your laptop to a service center for further diagnosis.
02-25-2025 04:35 PM
@Blackmesaja
03-01-2025 01:56 AM
After a few tests, I can confirm that the issue is indeed with the button.
Thanks for the quick help, best regards.
