Cooling fan wont turn on anymore
mksnhpc
Hello everyone,
I have a Asus Zenbook 13 UX325EA running on Windows 11 64-bit. The fan was working as intended a couple of days ago but now has suddenly stopped working at all and as a result the laptop is overheating. There's no fan control options in the BIOS either and i've checked all other windows settings but to no avail. So, if anyone can help me solve my issue, i'd be very grateful!
TIA 🙂
4 REPLIES 4
Falcon_ASUS
@mksnhpc
Please refer to the following FAQ to diagnose whether the fan is abnormal through the MyASUS.
https://www.asus.com/support/FAQ/1015064/
Hello! Thanks for the quick reply! i dont have any option to diagnose fan in the myAsus app. I amattaching the screenshots of the same below
@mksnhpc
If MyASUS does not have this option, it means that your laptop does not support this feature for detection. If the fan is not working properly, it is recommended to send it in for repair.
ZenBot
Community Manager
Community Manager
