ASUS Zenbook UX5401EA-PURE4X max resolution external displays(USB-C)
I'm trying to connect two 4K displays to this computer through a USB-C hub.
It will only allow me to get 4K@60hz + 4K@30Hz.
Is it possible to get dual 4K@60Hz through this laptop?
(I want them both through the usb-c hub which supports dual HDMI 4K@60Hz, it's non-TB3/4 but compatible)
Thanks in advance
Falcon_ASUS
gustafjohansson
Thanks in advance
@gustafjohansson
If you are using it through a USB-C hub, it can only output 4K@60hz + 4K@30Hz.
According to your needs, I would recommend you to use it via TBT4.
ASUS_Bot
Rising Star II
