laptop is lagging so much and plugged in but not charging!
ananthan2548
System: Windows 11
Battery or AC: Both
Model: Vivobook 15 X512DA
Frequency of occurrence: random
Reset OS: NO
Screenshot or video: N/A
Detailed description: Sometimes my system is so much lagging. when I try to refresh, the desktop icons disappear and come after 4 to 5 seconds. Everything feels slow and laggy.
And at that time when I tried to plug in, the charging symbol is showing but the battery percentage is not increasing even after 1hr. So I ran the My Asus app system diagnosis and it said that there is some problem with the AC adaptor or battery.
So I shut down the system and after some time I again plugged in my laptop without 'turning ON'. And the red LED indicator was 'ON' showing that it is plugged in. And when I checked after 1 and a half hr the LED was white, showing that the battery is almost full.
So I again turned on the system and ran the My Asus system diagnosis. This time it said to me the AC adaptor and charger is OK. And for the first 2-3 minutes system behaved like normal but after a couple of minutes, it again started to lag so much.
I was not having any lag till yesterday. The system was completely normal. The issue started today. My system was operating in windows 10, So I thought that updating to windows 11 will fix the issue. So I updated it to windows 11 today. But it didn't solve it.
Please someone help! I don't know what to do!
6 REPLIES 6
ananthan2548
Falcon_ASUS
https://zentalk.asus.com/en/discussion/54533/laptop-is-lagging-so-much-and-plugged-in-but-not-chargi...
@ananthan2548
According to your describing , I would like to suggest you to bring back your laptop to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
If I bring my device to the service center they will probably say that the motherboard should be replaced! and I'm now out of warranty period, so it's gonna cost me a lot!
After some research on the issue, I found about 5 to 6 same issues reported here and in the AMD community.
You guys literally cheated us!! There is some kind of serious manufacturing defect on the motherboard.
This is my first laptop. After so much hard work and struggling, I bought it, but now I think I lost my hard-earned money. I don't have that much money to replace the motherboard or to buy a new laptop, so I'm really trapped now! ASUS cheated me!
I will never buy an ASUS product in my life again and also will not recommend it to others.
Please guys,
If you don't want to waste your hard-earned money, don't go for ASUS products!
I lost mine and now I don't know what to do.😓
Falcon_ASUS
ananthan2548
https://zentalk.asus.com/en/discussion/comment/192829#Comment_192829
Please guys,
@ananthan2548
Sorry, because you mentioned installing the system to Windows 11, the problem still exists.
So I would still suggest you send the laptop for repair.
