Zenbook 14 battery stuck on 47% and won't get charged and only works plugged in
redington
Hi, the title pretty much says the issue
I want to know if this is an indicator that i have to change my battery or is there is simpler less expensive solution?
Falcon_ASUS
@redington
Based on your description, it is possible that the battery is malfunctioning. We recommend that you send the laptop to a service center for further inspection.
does battery malfunction mean that it needs to be replaced with a new one?
@redington
Yes, but the actual situation still needs to be confirmed by the service center through inspection.
