HDR issue
3dmikee
Rising Star I
System: Win11
Battery or AC:
Model: vivobok 15 m513 ryzen
Frequency of occurrence: every time
Reset OS: no
Screenshot or video: https://www.youtube.com/watch?v=2z8c-84ZCvA (this guy showed on video same issue)
Detailed description:All videos show crazy colors, some more or less. Rebooting helps temporarily until you use HDR again.
Steps to reproduce:
1. enable HDR
2. disable HDR. If not visible, turn on full screen mode or scroll up-down the page
Current driver versions:
1. AMD Radeon Graphics - 30.0.13044.3001
2. Vivobook UEFI - 10.1.2.312
Also AMD Graphic Control Panel Apllication wont start up.
78 REPLIES 78
Arjun_C
3dmikee
https://zentalk.asus.com/en/discussion/comment/222578#Comment_222578
Waiting for August to update their services. This issue first appeared after installing Splendid, which was barely installed after a couple of attempts. Reddit keeps posting similar threads but no one knows the solution
Please update whatever happens over here
3dmikee
Rising Star I
Continuing to observe the problem.
In Firefox everything is fine  (it does not support HDR). Not observed in Media Player Сlassic, but occurs in the built-in WIndows video player.
Is there any relation to AMD driver? There are different video profiles in driver settings, all of them cause color distortions, including on the default setting. But it is possible to set a user profile and decrease brightness by -30% and it becomes imperceptible except for the distortion of the thickness of the pixel. And this is not the solution: it makes the video darker, and you have to change the slider every time to get rid of this distortion.
And if you cover the video window of another program/popup colors become normal! (this is written about it on reddit)
Arjun_C
Okay here is my update on this, so far I have only noticed this on Edge/Chrome browsers, and this can be solved by disabling hardware acceleration in browser settings, but then you will lose other featuresres and sometime high res video playback might get choppy. I tried uninstalling ADM and Nvidia drivers still no luck. I belive it some graphics or display driver bug, I'm using windows 11 idk if this issue is there in windows 10
3dmikee
Rising Star I
HDR does not work with hardware acceleration turned off. And ASCI new release came out and didn't bring good news, still experiencing this issue
Users keep writing about this bug, will we get a fix?
Asus Vivobook
https://www.reddit.com/r/ASUS/comments/wzyn4e/color_in_my_asus_vivobook_oled/
Asus Vivobook pro 16x
https://www.reddit.com/r/ASUS/comments/wiiyt6/my_vivobook_pro_16x_4k_oled_laptop_shows_colors/
Asus ROG Zephyrus G15
https://www.reddit.com/r/ZephyrusG15/comments/x34pui/display_gets_weirdly_hdr_and_better_looking_whe...
3dmikee
Rising Star I
Here is another way to solve the problem: you can easily deactivate MyAsusSplendid by deleting the color profile in the folder C:\ProgramData\ASUS\ASUS System Control Interface\ASUSOptimization\Splendid\X513UA_1002_834C4161.icm (It may have a different name on your laptop)
But unfortunately all these methods also deactivate OLED Flicker-Free Dimming setting in MyAsus.
UPD: I think I finally solved the damn problem without touching Splendid!  I'll post the solution on Monday, September 5, but in the meantime I'm testing.
