Asus Vivobook pro 15 Randomly Shutsdown while I am working
poojan_s_
I have Asus Vivobook Pro 15 M3500QC. Recently for few days my laptop shutsdown loosing all my work from nowhere. What can be the issue? Is it the motherboard Issue or Windows? I recently replaced my speakers and left side fan as my laptop is under warranty.
Any help will be greatful.
Here are some specs:
Processor
  • Model: AMD Ryzen 5 5600H with Radeon Graphics
  • Cores: 12
  • Speed: 4.2 GHz
  • Stepping: 0
  • Family: 19
  • Model Number: 50
  • CPU ID: 178BFBFF00A50F00
Memory (RAM)
  • Total: 16 GB
Graphics
  1. AMD Radeon(TM) Graphics
    • Chipset: AMD Radeon(TM) Graphics
    • Manufacturer: ATI
    • Hardware T&L: Yes
    • Total Memory: 9.0 GB
    • Dedicated Memory: 1.0 GB
    • Driver Version: 30.0.13044.14002
    • Vertex Shader Version: 6.0
    • Pixel Shader Version: 6.0
    • Plug and Play ID: VEN_1002&DEV_1638&SUBSYS_186C1043&REV_C6
    • Device ID: 1638
    • Vendor ID: 1002
  2. NVIDIA GeForce RTX 3050 Laptop GPU
    • Chipset: NVIDIA GeForce RTX 3050 Laptop GPU
    • Manufacturer: Nvidia
    • Hardware T&L: Yes
    • Total Memory: 12 GB
    • Dedicated Memory: 4.0 GB
    • Driver Version: 32.0.15.6614
    • Plug and Play ID: VEN_10DE&DEV_25A2&SUBSYS_186C1043&REV_A1
    • Device ID: 25A2
    • Vendor ID: 10DE
Operating System
  • OS: Windows 11
  • Version: 10.0.26100
  • Architecture: 64-bit
  • Locale: 4009
BIOS
  • Version: M3500QC.316
  • Manufacturer: American Megatrends International, LLC
Thankyou.
simon44
Falcon_ASUS
@poojan_s_
If the laptop randomly shuts down during use, it is recommended to take it to a service center for further diagnosis.
