Fan speed control on Vivobook 15 X509FJ
RanchTheHay
I'll be real honest , the temperature-fan speed curve on this laptop sucks , Only after the CPU hits 95c and throttles the fan hits a high speed and its quite useless at that point when the CPU has throttled down to like 2.2ghz
After using the MYASUS app-the fan diagnostic tool , I realised that the fan can spin at speeds higher than 3000rpm (ofc the sound says it all , and i see a temporary temperature drop during the diagnostic test when the fan runs at a high speed than usual)
So I tried using Notebook Fan Control , and No avail  , Even tried making my own config...still does not work and it honestly sucks when the fan can do more , but you want to lock it at lower speeds (My older dell had the fan speed set at 100% all the time...it did not explode or something...and I dont mind getting a fan replacement even if the fan decides to give up)
Model : Asus X509FJ - model with a i5-8265U and a MX230 GPU
BIOS version : 302  (pls don't ask me to upgrade it to 303 , v303 locks voltage controls(cannot undervolt which was helping me to control the temperatures) and my laptop idles at 75c for no reason (even after cleaning up and a thermal repaste)
9 REPLIES 9
RanchTheHay
Any ways to get fan speed control?
@RanchTheHay
Please enter MyASUS to confirm whether you can make further settings through Fan Profile.
https://www.asus.com/support/FAQ/1045651/
Nope , that option is missing in the MyAsus App
RanchTheHay_0-1681958878577.png\
I even recall having an option to change the color profile of the display here , which vanished out of thin air
@RanchTheHay
Fan Profile*The features supported will vary by model.
If there is no such option in MyASUS, it means your model does not support this function.
