09-10-2021 12:59 AM
09-21-2021 08:31 AM
Gustav_ASUSI contacted Asus to find out the problem on my phone and they replied that due to privacy issues they could not give me directions !!!! Asus knows that I am registered with two smartphones with a lot of name and surnameTo clarify - what I meant was that it can be caused by hardware issues of any kind. We can't know the underlying cause for each individual case. This is the same information that I've been giving you before in this thread.
If you happen to be affected by this issue, please contact a local ASUS service center for support.
09-21-2021 08:32 AM
09-21-2021 09:09 AM
CVAnyone else affected in the UK? As I clearly don't want this phone anymore as this fault will likely happen again. How do we put pressure for a refund instead?Don't put your hopes up guys.
Recall will likely happen if there's a safety issue like the Note 7 case. Most we may likely get is a repair, refund or replacement, depending on your consumer/lemon laws. I am as devastated not having a phone and not being able to recover data.
09-21-2021 09:21 AM
marzvinWould a formal petition to Asus help? We can gather complains from across the globe with people having the same issue. Or we can raise it to a international committee or something that can help raise this case against Asus?https://zentalk.asus.com/en/discussion/comment/186952#Comment_186952
09-21-2021 09:23 AM
Gustav_ASUSWith all the cases you have on hand, were you able to get findings then from the different service centers? I'm sure some of the cases were already closed, can you then provide us what are the root causes for those cases?To clarify - what I meant was that it can be caused by hardware issues of any kind. We can't know the underlying cause for each individual case. This is the same information that I've been giving you before in this thread.
