12-08-2020 08:57 PM
12-08-2020 11:15 PM
akshayjamwal876@gmail.comVolume bar:- For volume bar it is not a lag but stock behaviour,diffrent usage has diffrent behaviour of volume bar for few apps its press & full volume and for few other apps its press press volume key to increase or decrease volume so it is not a bugNormally you can do full volume or mute by just holding volume buttons but while using using earphones if i kept it pressed nothing happens.While watching videos and playing games specifically.I also did a factory reset but the problem still persists. After reset i am also facing that pinkish tint in google chrome which was not there earlier .
This issue i am facing after updating to the latest update many more people are also facing this issue.
Volume bar lag and chrome pink tint issue
12-09-2020 06:46 AM
akshayjamwal876@gmail.comBoth of these issues will be solved in Android 11Normally you can do full volume or mute by just holding volume buttons but while using using earphones if i kept it pressed nothing happens.While watching videos and playing games specifically.I also did a factory reset but the problem still persists. After reset i am also facing that pinkish tint in google chrome which was not there earlier .
12-10-2020 12:42 AM
akshayjamwal876@gmail.comFor the chrome issue, go to chrome flags, there is option for dynamic color gamut or something like that, just disable that. I also had same issue in chrome and that issue is solved now.Normally you can do full volume or mute by just holding volume buttons but while using using earphones if i kept it pressed nothing happens.While watching videos and playing games specifically.I also did a factory reset but the problem still persists. After reset i am also facing that pinkish tint in google chrome which was not there earlier .
12-17-2020 02:46 PM
Anders_ASUSSo was it Chrome's or Asus' fault (chrome pink tint issue)?https://zentalk.asus.com/en/discussion/41454/volume-bar-lag-and-chrome-pink-tint-issue
