09-16-2024
01:46 AM
- last edited on
09-17-2024
06:51 PM
by
Falcon_ASUS
I'm using Asus ZenFone Max Pro (ZB601KL) M1, I'm facing these multiple problems,
1. Lower volume button not working
2. Even after connecting usb, I can only charge the device but I cant see USB tetharing option, which mean i cant able to access or share files using USB
check this snippet
I have connected USB but no usb tethering option avaible, its just charging
3. Main issue after I reboot or power of device I get like this
your device is corrupt. It cant be trusted and may not work properly
VIsit this link on another device:
g.co/ABH
PRESS POWER KEY TO CONTINUE
Kindly provide me solution these problems ASAP
details of my phone
Registration Date : 2019-04-02
Serial Number: J7AAG**********
09-17-2024 06:51 PM
@vittysg
Have you tried performing a system restore on your phone?
If the issue persists after the system restore, I would suggest you bring back your device to our service center for further confirmation.
