Loud static sound when using wired headphones
https://zentalk.asus.com/t5/zenfone-10/loud-static-noise-when-connected-to-wired-sony-wh720n-headpho...
The exact same issue even with same the headphones too, only I am using Zenfone 9.
Other wired headphones work fine with phone. The problem headphones work with other devices, but not Zenfone 9.
The static isn't too bad with very low volume. The static is bad when I increase the volume or touch the headphones.
I checked and there is no dust in my Zenfone 9 headphone jack, so it's probably a software or compatibility issue.
Any solutions yet?
gladykov
Contrary. This is hardware issue. Buy external USB DAC - you will have better sound quality anyway
