4 weeks ago
I just bought the zenbook s16 with AMD 9 HX 370
The spec clearly states it supports 1x HDMI 2.1 TMDS
When I plug in my dell 40 inch 5120x2160 ( U4025QW ) the system only reaches refresh rates reach till 50 hz.
I want to get it to 60hz at least. My other laptop works fine with this deplay at 5120x2160 at 120hz.
Below are some of the things I have done until now which did not help:
-I have updated the drivers
-I bought new HDMI cable which is certified 2.1 specs.
-I tried using USB version 4 as an alternative. This did not work either.
-I downloaded the amd andrelanin edition and tried to create a custom resolution. In this case I will able to get it to 5120x2160 51 hz. Anything more than that I got an error "The custom resolution settings re not compatible with this display. Reconfigure your settings and try again".
I have ran out of options. Please advice what else can I do?
Thank you
K
Solved! Go to Solution.
3 weeks ago
Hi @Falcon_ASUS ,
Please find the dell monitor diagnostic report when attached to the laptop
https://gist.github.com/vishalkhialani/a4ba46fcd2e5d54e15e6cd97f66c5b47
Also I have decoded the EDID for reference when attached to my laptop - EDID-
https://gist.github.com/vishalkhialani/8395823f0318a32dc95321a13b9768db
Hope this helps.
Thank you,
K
3 weeks ago - last edited 3 weeks ago
@kachaloo
Upon confirmation, HDMI 2.1 can be divided into two specifications: TMDS and FRL.
UM5606WA only supports TMDS, so it cannot support 5K resolution.
We apologize for any inconvenience this may cause.
2 weeks ago
Thank you for the update
