10-29-2024 06:46 AM
Zenbook S 16, display edge paint peeling off. Is this wear pattern normal after just 2 months of use?
I am always carrying my laptop in a fleece lined laptop bad, and paint abrasion happens from the minimal friction inside the bag.
10-29-2024 11:09 PM
@PaulNi2
Does your laptop bag have enough space?
Given your situation, we recommend that you bring both your laptop and the bag to the service center for the staff to check.
