What to do when my ux8402ZE is not as advertized?
FongPoui
Rising Star II
System: WIndows 11
Battery or AC: UX8402ZE
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:Due to a problem found for the connection of an external sandisk extreme pro v2 whose speed can go up 2000 mbs, I have searched for info about my zenbook 14 duo pro i7 and reread its manual, I found that the specification of port usb 3.2 described in the manual is usb 3.2 gen 1, not usb 3.2 gen 2 as advertized on the web sites, both in Thai and in English.
In Thai, 1x USB 3.2 Gen 2 Type-A
In English, 1xUSB 3.2 Gen 2 Type-A
But in Thai manual, it is published: 3 Port USB 3.2 Gen 1 Port USB 3.2 (Serial bus 3.2) Gen 1, Data transfer rate up to 5Gbits/s and can work with old USB 2.0
What do I have to do? I cannot benefit from my Sandisk speed.
I bought this model as advertized on the web sites, not on the manual.
How can I upgrade the port usb 3.2 Gen 1 to port usb 3.2 Gen 2?
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon_ASUS
FongPoui
  1. System: WIndows 11
  2. Battery or AC: UX8402ZE
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
@FongPoui
I have replied to you in here.
Falcon_ASUS
https://zentalk.asus.com/en/discussion/64181/how-to-confirm-the-usb-3-2-type-a-port-is-really-gen-2
@FongPoui
Confirmed by the technical unit, the USB port (Type-A) of UX8402ZE is USB 3.2 Gen2 2x1 (10Gbps).
Regarding the wrong part of the description in the user manual, I have reported the relevant unit yesterday.
There is no problem with the USB specification on ASUS website, the USB port (Type-A) of UX8402ZE is USB 3.2 Gen2 2x1 (10Gbps). About the wrong part of the manual description, I have reported the relevant units. Sorry for any inconvenience it may be caused.
Falcon_ASUS
FongPoui
  3. Model:
  5. Reset OS:
@FongPoui
Falcon_ASUS
@FongPoui
ASUS_Bot
Rising Star II
