Problem with constant switching external monitor on and off
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-20-2019
05:02 AM
- last edited on
01-16-2024
12:20 AM
by
ZenBot
System: Windows 10
Battery or AC: AC
Description: Problem with constant switching external monitor on and off
Model: ZenBook Pro 15 UX550GD
Frequency of Occurrence: Always
Reset OS: No
Hello, I have external monitor which I connect to the laptopover hdmi/Usb C – I tried both ways.So what happens is that I select to show my desktop on thesecond external monitor only. Then the monitor keeps switching off and on everysingle minute until I unplug the cable and use the laptop screen only. I tried to show desktops on both, did not help either to solve the issue.My model is: https://www.asus.com/Laptops/ASUS-ZenBook-Pro-15-UX550GD/Tech-Specs/ Thanks for any help, it is really frustrating to work this way :-(((
Battery or AC: AC
Reset OS: No
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-14-2019 11:31 PM
Hello vaclav.schmuttermeier,
What kind of cable and external monitor are you using?
Have you tried to use another cable or dock?
The chip-set might not matched.
Thank you for messaging us.
Have a nice day.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-15-2019 04:01 AM
i checked technical specs of laptop and i found it supports two external monitors AND LAPTOP igpu has Intel® UHD Graphics 630
Graphics Output eDP/DP/HDMI/DVI
4K Support Yes, at 60Hz
Max Resolution (HDMI 1.4)‡ 4096x2304@30Hz
Max Resolution (DP)‡ 4096x2304@60Hz
Max Resolution (eDP - Integrated Flat Panel)‡ 4096x2304@60Hz/
Mkght be graphics drivers of related softwares are coruppted,
Make sure ,your external monitors supports hdmi 1.4 or not ?
