How to disable power to the USB/Thunderbolt connected devices when my computer is turned off?
stojanovic83
System: Windows 11
Battery or AC: Both
Model: Asus ZenBook 14 UX425EA
Frequency of occurrence: Constant
Reset OS: Yes
Screenshot or video:
Detailed description:
Hello,
I have a problem that all my devices connected through USB C ports are still powered when I turn off my computer (e.g. my external keyboard’s lights are still on when computer is turned off, external fan...)
Is it possible to disable power providing to external devices when computer is turned off, or I have to unplug them each time I shut down my computer?
Falcon_ASUS
stojanovic83
  1. System: Windows 11
  2. Battery or AC: Both
  3. Model: Asus ZenBook 14 UX425EA
  4. Frequency of occurrence: Constant
  5. Reset OS: Yes
  6. Screenshot or video:
Hello,
@stojanovic83
Unfortunately, I have confirmed that there is no relevant option in the BIOS to disable this function.
