Help with system fan replacement
Unicus
HI everyone,
I need help, I am from Canada and I need to buy a fan for my Zenbook Model Q304U.  The fan is dying. I blew it out, full of dust worked for an hour and then started making horrible sounds.  The drive is a SSD.  So it the fan, any advice on what type of fan I have to buy from Amazon.ca?
See attached photo and this close up of the part number on the fan
https://app.screencast.com/sUwZTjScCXpgm
Asus support was no help, they wanted me to send it in for repair.  I can't afford that.
13 REPLIES 13
phermous
This is not amazon.ca, but it should bring you closer:
ASUS Q304UA 2-in-1 Fan (ifixit.com)
So you need an KDB0705HB fan with the proper formfactor. I am not familiar with the exact structure of these but it is possible that you can change only the fan inside the cover.
Best
NO that does not help, I found a fan but they want 250 bucks.
Its doesn't say Q304U
