ScreenPad+ MaxView feature is not working anymore
Nyxtalgia
Hello! Does anyone can help me with a minor problem I have on my Asus Zenbook 14 duo.
At first, whenever I click and drag a certain window, it displays an option where you can MaxView your selected window and display it both on screen 1 and 2 of my laptop. However, as some system updates had occured, I cannot use it anymore. I am using a ZenBook duo 14 the "first version" not the elevated ScreenPad+
Jiaszzz_ASUS
Hello, @Nyxtalgia .
Could you please provide the full model name of your Asus Zenbook 14 duo? (for example, UX8402ZA or UX8402ZE)
I am unsure about the "first version" you mentioned.
May I ask if you could provide the exact version number you currently have installed and a video of the problem for us to better understand your problem?
Does the MaxView is a third party application?
Have you tried to uninstall and reinstall to solve the problem?
UX481FL is the model.
I have tried installing/uninstalling it but to no avail
Hello, @Nyxtalgia .
Thank you for confirm the model name.
Could you also help determine the utility and the scenario as well?
Thnak you.
