Display Problem - Icons - Text Titles - Menus far to Small for my Eyes
stitch-up
My ASUS - ZenBook Pro Duo UX581GV 15.6” Laptop - Intel® Core™ i9, 1 TB
SSD, Blue
Graphics card: NVIDIA GeForce RTX 2060, 6 GB GDDR6
I'm experiencing visual issues with some software - Wilcom ES3 (Wilcom Embroidery Studio 3) the screen displays items such as menu titles & contents, icons, so small making the software hardly usable e.g. hardly usable or readable - How can this be solved?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon_ASUS
@stitch-up
This should be caused by a software configuration issue on your end.
We recommend checking if the software provides an option to adjust the percentage size.
For the laptop itself, it is suggested to adjust the font size in the display settings for confirmation.
[Windows 11/10] How to change Screen Size, Display Resolution, and Refresh Rate in Windows Display
Change the size of text in Windows
Falcon_ASUS
@stitch-up
