Asus Zenbook Pro 16X OLED ux7602zm with external monitor via USB-C
rafalseweryn
System: Windows 11
Battery or AC: both
Model: Asus Zenbook Pro 16X OLED ux7602zm
Frequency of occurrence: always
Reset OS: yes
Screenshot or video:
Detailed description:
I want to connect external monitor LG Gram View 16
but it doesn't work.
LG's manual says:
"This product is designed to be used only with a laptop. The device to be connected with the monitor must support DisplayPort Alternate Mode (DP Alt Mode) and power output (USB PD) at 7.5 W (5 V / 1.5 A) or higher. "
The Asus manual says:
Thunderbolt™ 4/Power Delivery combo port
The Thunderbolt™ 4 port is compatible with USB Type-C®
standards, and provides a transfer rate of up to 40 Gbit/s for
Thunderbolt™ 4 devices. Connect your Notebook PC to a
DisplayPort, VGA, DVI, or HDMI external display and experience
high-resolution display features via Intel® Thunderbolt™
technology. Connect a power source rated 20V/5A to charge the
battery pack and supply power to your Notebook PC.
10 REPLIES 10
FongPoui
Rising Star II
Why does my monitor keep showing no signal even though the DisplayPort cable is connected properly, ...According to that explanation, is a problem of how to plug/unplug or connect/disconnect the monitor to the port?
Falcon_ASUS
rafalseweryn
  1. System: Windows 11
  2. Battery or AC: both
  3. Model: Asus Zenbook Pro 16X OLED ux7602zm
  4. Frequency of occurrence: always
  5. Reset OS: yes
  6. Screenshot or video:
LG's manual says:
@rafalseweryn
Have you updated your current BIOS and system versions to the latest?
Could you please take a photo of the connection between the laptop and the screen for me to confirm?
rafalseweryn
FongPoui
https://zowie.benq.com/en-ca/support/faqlist/troubleshooting/faq054.html#:~:text=3)%20If%20the%20Dis...
I doesn't matter, when i connect monitor via usb-c cable the connection doesn't work. I can't connect it to the laptop.
rafalseweryn
Falcon_ASUS
https://zentalk.asus.com/en/discussion/65830/asus-zenbook-pro-16x-oled-ux7602zm-with-external-monito...
@rafalseweryn
Yes, i've updated to latest (303) version of bios.
Monitor has two USB-C ports - i tried both of them
Laptop has two USB-C ports - i tried both of them.
When I plug the monitor, i can see LG logo on monitor for a while, but laptop doesn't detect monitor.
I tried two different cables, original one from LG and second, which i use everyday to work with the same monitor but with other computer.
Regards...
