ZenBook Duo 14 (UX482EG) stylus
sonati
System: Windows 11, 64bit
Battery or AC:
Model: UX482EG
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Recently i lost my stylus (ASUS Active Stylus SA201H) that came with my device when i pursached it, and i tried to buy the same model, however I was unable to find any aviable.
I asked on Asus support about compatible models, and i was told that model SA300 is compatible. After buying it i found out it doesnt work on my device and i don´t know how to resolve this issue.
Are there no other pens compatible with my model?
5 REPLIES 5
Falcon_ASUS
sonati
  1. System: Windows 11, 64bit
  2. Battery or AC:
  3. Model: UX482EG
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
@sonati
Your laptop can only use the SA201H stylus. (MPP 2.0 compliant)
sonati
Would it be possible to use a different brand stylus, if it's MPP 2.0 comliant? Or does the type of the stylus tip also matter?
Falcon_ASUS
https://zentalk.asus.com/en/discussion/65853/zenbook-duo-14-ux482eg-stylus
@sonati
sonati
I contacted the asus support again and this time they told me i could use asus stylus SA203HA. Would that work with my model?
Falcon_ASUS
sonati
@sonati
Basically, the stylus can be used if it supports MPP 2.0.
Also, I only found SA201H on the website.
ASUS PEN SA201H|Stylus|ASUS GlobalSorry for any inconvenience it may be caused.
