Vivobook X15022, poor sound quality when using a USB headset
ProcomIT
We have 8 x  Vivobook X15002 laptops and all are experiencing poor sound quality issues when using USB connected Headsets.
The headsets work perfectly with other models and brands, but same issue on ALL the Vivobook X15002 models.
Has anyone else experienced issues ?
Many thanks
rory586
Hello,
Many thanks
Your headphones aren't working right on your new laptop!
Let's try to fix the.
Update Audio Drivers: Check for updated audio drivers on the ASUS website and install them. Check for BIOS Updates: Sometimes, BIOS updates can resolve audio-related issues. Disable Audio Enhancements: Turn off any audio enhancements or equalizers in Windows settings. Test Different USB Ports: Try using different USB ports on the laptop to see if the issue persists.
williamwalker
Have you checked the audio settings? Maybe there's a setting specific to USB devices that needs adjusting.
Falcon_ASUS
@ProcomIT
Could you please provide the complete model name of the laptop you are using?
How to find Model Name
What are the current BIOS version, system version(operating system build number),  and audio card driver version you are using?
Additionally, could you please provide the brand and model of the headset you are using?
