03-24-2023 10:33 PM
I am wanting to connect my vivobook pro 16 to a 34" monitor at (3440 * 1440) at the highest refresh rate possible, something like a ASUS VG34VQL1B TUF Gaming VA UWQHD.
Haven't found any documentation as to what my vivobook will support using with HDMI, USB-C or Thunderbolt 4?
Can someone help me on working out what modes are supported for external monitors.
My model is K6602HC
03-26-2023 07:24 PM
@greg_in_aus
HDMI max resolution,frequency: 1920*1080,60Hz
USB Type-C support display max. resolution, frequency: 3840×2160, 60Hz
Thunderbolt display max. resolution,frequency: 3840*2160,60Hz
03-28-2023 05:08 AM
Thanks for the info, would you know if you can run 3440 * 1440 @ 144hz ... or if i was to pair this with the "ASUS ProArt Display PA348CGV" would it run at the 120hz via USB-C ?
03-28-2023 06:41 PM
@greg_in_aus
Unfortunately, as far as I understand it cannot be used in this way.
