Overheating issue announcement on Android 14
Sam1991
Rising Star II
All users who are experiencing high overheating issue on your ROG 7 please follow these steps and send your long to the moderators @Mattias_ASUS . He is gathering all the logs and going to send them to dev team. Hopefully, if we all send our logs we get a fix soon.
For more information,he also mentioned this on the following thread:
https://zentalk.asus.com/t5/rog-phone-7/bandaid-fix-on-asus-phone/td-p/425747
To the people experiencing this issue: I am gathering logs for the dev team regarding this issue, for this to actually work the logs need to be created while using the phone normally and please write down the timestamp on when the heating is occurring, when you are done please send me a PM with the link for the logs.
The steps to create the log are here:
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
13 REPLIES 13
The moderator just recently replied to me, I want to correct this mistake, and I will send him the logs, and write more just in case. (If interesting I sent a photo where the heating was)
Awesome , please do and reach out to him. I follow up everyday regarding our issues. Hopefully , we get a fix soon.
Fully support
kmcmurtrie
Rising Star II
Weird.  I have the opposite problem in A14.  Battery life is amazing...because apps keep stalling.  It's about 4 seconds at a time.  If it's a foreground task, it runs as long as it's being touched.  Apps relying on a background task stall constantly.  It's miserable to use.
I can't find anything in logcat, but Google did implement aggressive power saving in A14 (because their own trash apps run the battery dead).
