11-12-2020 06:04 AM
11-17-2020 01:35 AM
11-17-2020 06:37 PM
11-24-2020 03:09 AM
11-24-2020 05:27 PM
n.claudiu7Hello n.claudiu7,I have the same wi-fi problem on an Asus FA506IV. Every 30-40 minutes of gaming (using wi-fi), I start to have lag spikes. If I switch the connection (I make hot spot from mobile phone), the MS becomes normal. Also, every update is made and I use other laptops from the same spot which run perfectly. Is it the wi-fi card the problem on the Asus laptop?
11-25-2020 02:50 AM
Blake_ASUSHello. My BIOS version is: American Megatrends Inc. FA506IV.311, 11.09.2020. Hope that is what you asked. Is it ok?https://zentalk.asus.com/en/discussion/comment/135288#Comment_135288
Hello n.claudiu7,
May I have your BIOS version?
If you have done some cross check, it would be better if you can send the device to our service center to check on the hardware. Sorry for the inconvenience caused.
