Rog Strix Go 2.4 Wireless headset - Replacement Dongle
trb234
System: Windows 11
Battery or AC: Battery
Model: Rog Strix Go 2.4
Frequency of occurrence: N/A
Reset OS: N/A
Screenshot or video:
Detailed description:
Hello, is it possible that a replacement dongle can be obtained for this headset as I have managed to break mine. I tried contacting support via the form but I cannot find the serial number for the headset on the headset itself and I no longer have the box.
Falcon_ASUS
trb234
  1. System: Windows 11
  2. Battery or AC: Battery
  3. Model: Rog Strix Go 2.4
  4. Frequency of occurrence: N/A
  5. Reset OS: N/A
  6. Screenshot or video:
@trb234
Here we mainly discuss the issues/questions related to ASUS laptop.
For your Headset questions, I suggest you contact our local call center to have further assistance.
Please refer to below and find the link of local call center.
ASUS - Contact UsSorry for any inconvenience it may be caused.
ASUS_Bot
Rising Star II
