ROG B650E-E - Question about USB and Power (Watts) (Future use for Quest 3)
claus1
Hello guys!
I have one question about this board. How many Watts I can get (maximum) on the rear USB 3.2 Gen 2x2 port ???? I know it is a 20Gbps, I plugged one cable that can support 100W and 20Gbps.
And testing with a powerbank to see how much power it uses, and I get around 6 to 7W only.
It is normal??? it's not supposed to be more?
I think that will not be enough to play with Meta Quest 3 while charging right?
It have any settings in the BIOS to adjust and give more power?
Thanks guys!
Falcon_ASUS
@claus1
For your question, we recommend posting it here to seek answers.
https://rog-forum.asus.com/t5/gaming-motherboards/bd-p/HSS_MB
