3 weeks ago
Recently got the Zenbook Duo, Scenario s using both screens as one virtual screen, scrolling Chome or Edge pages covering both pages.
There is a gap between the two screens where several rows of data are missing. You can scroll up or down to see them.
Ideal would be to see the bottom of the upper screen continue on the lower without missing the several rows of data.
Talking to Customer Support, there does not seem to be fix for this.
Anyone else run into this limitation and any work around ?
Solved! Go to Solution.
2 weeks ago
2 weeks ago
Figured out a solution. Hide the Task bar in settings.
