External Power Supply for external Blu Ray Drive SBC-06D2X-U
Gio_Tee
System: Windows 11
Battery or AC: AC
Model: SBC-06D2X-U
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:Hi there,
I've purchased recently the external Blu Ray drive SBC-06D2X-U for my UX482 Zenbook duo.
The Blu Ray drive comes with a Y-USB-Cable for data and power supply. As the Zenbook has only one USB-Port I would like to connect the Data-Cable to the laptop and the power supply cable to a charger.
Can anybody confirm that this is OK? According to the label on the backside of the drive the demand is 5V/2.0 Amp. I have a charger for my old Beats By Dre Headset with 5V/2.1 Amp. - can I use this?
Or should I purchase a mini-USB 2.0 to USB-C cable?
Thanks
Gio
4 REPLIES 4
Falcon_ASUS
Gio Tee
  1. System: Windows 11
  2. Battery or AC: AC
  3. Model: SBC-06D2X-U
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Thanks
Gio
@Gio Tee
It should be no problem, but I still recommend you to ask the manufacturer of Blu Ray drive again whether the operation method can be executed. Thank you.
Gio_Tee
Falcon_ASUS
https://zentalk.asus.com/en/discussion/61095/external-power-supply-for-external-blu-ray-drive-sbc-06...
@Gio Tee
Dear Falcon,
manufacturer of the Blu Ray drive is Asus 🙂
I've connected the main USB-plug from the Y-cable on the USB-port of the Zenbook duo and it works without any problem. You can even burn a Blu Ray disc. I asume that the USB-port of the computer has enough power for the external drive.
But I am still confused why Asus is using an Y-cable which is not a standard.
I think the best way is to purchase a mini-USB 2.0 to UBS-C cable.
BR
Update: I've contacted the German customer support by phone. They told me that I can plug the USB-A from the drive to a USB-A to USB-C adapter. This will work on the Zenbook without problem.
Falcon_ASUS
Gio Tee
https://zentalk.asus.com/en/discussion/comment/214854#Comment_214854
Dear Falcon,
BR
@Gio Tee
We apologize for any inconvenience caused and your valuable advice will be included in future design and optimization considerations. Thank you.
ASUS_Bot
Rising Star II
