Battery won't charge
Emirardita
Battery won't charge in windows 11 is there some solution or i need to change battery
Falcon_ASUS
@Emirardita
Could you please let me know the complete model of the laptop you are using?
We recommend referring to the following FAQ to perform an initial battery check using MyASUS.
How to find Model Name
Troubleshooting - Device’s Battery not supplying power/charging, Battery not charging to full, Unabl...
