Battery saving feature
StudioBook H5600Q has a bug with battery saving functionality. When I set up to charge battery not more then 80% this functionality applies just for the main charger and do not work in case laptop charges with USB Type-C power delivery. I believe that this functionality should apply to any charge input.
7 REPLIES 7
Falcon_ASUS
@sergii_cheliuk
May I ask for the BIOS version and system version (operating system build number) of your laptop? Additionally, I have sent you a message. Please provide your laptop's serial number through the message for further feedback. Thank you.
OS - Windows 11 23H2 Build 22631.3155
BIOS - H5600QM.321
@sergii_cheliuk
I have forwarded the information to the relevant department.
We will keep you updated and your consideration will be very much appreciated.
@sergii_cheliuk
After testing by the technical unit, the ASUS original ADP 100W PD can charge the battery to 80%, and it will not charge beyond 80% to 100%. Below are the relevant information during the test:
OS: 23H2 (22631.3155)
BIOS: 321
MyASUS: 4.0.6.0
ASCI: 3.1.24.0
If you still have concerns, please provide the brand/model, and operation method/video of the cable you are using, so that we can confirm again. Thank you.
