Battery Plugged in stuck at 3%
My battery isn't charging. It just says "plugged in" and its stuck at 3%. I replaced the battery, still its giving the same message. I did an EC reset, updated the bios, removed and re-inserted the battery, uninstalled power related items in the device manager, but nothing helped.
Is there any way to fix this?
My device is GL552jX
5 REPLIES 5
RAJU_MSC_MATHEM
Zen Master I
Vysakhkarthikeyan
Just boot with Linux live DVD ., login into Linux, then see if battery charges or not, if battery charges means , the your battery works well.
Hi Raju,
I tried even that. It's showing 3% even in linux and not charging.
etsachin
Vysakhkarthikeyan
Please mention the device model also go to performance tab in task manager and confirm that it isn't locked into 0.4Ghz
Blake_ASUS
Community Legend II
Hi there,
Is the battery changed by our service center?
I'm afraid that there might be issue with the motherboard.
