ASUS TUF F15 (FX506LI) Wifi Adapter disconnecting problem
SinOfPride
Model Name: ASUS TUF F15 / FX506LI
Firmware Version: BIOS 310 and Windows 10
Rooted or not: No Idea
Frequency of Occurrence: Everyday
APP Name & APP Version (If your issue relates to the app):NA
Hi, so here`s my problem, Most of the times when I disconnect the laptop from the ac adapter and then change the position of the laptop then its WiFi adapter gets disconnected, when I checked in the device manager it disappears from the device manager but I can see it if change the view to show hidden devices, but when I connect the laptop back to the AC adapter and then close the lid of the laptop/put laptop on sleep mode and turn it on again/awake laptop the WiFi adapter comes back and starts to work as normal. Does anyone know the solution to this because this is really annoying when in meetings.
ARP_ASUS
Hi SinOfPride,
ASUS Laptops isn't supported on Zentalk India.
Request you to please visit below links for service:
https://www.asus.com/in/support/
